Revit MEP Forum
Convert to wire in revit MEP 2015
1 REPLY 1
429 Views, 1 Reply
I have managed to create a lighting circuit successfully but cannot get the convert to wire command to show.  Neither do the 2 icons show up in the model space itself.  Have I got them turned off perhaps?  Can somebody help please?
1 REPLY 1
HermanSolomon
Hi KatyT,
Without a screenshot we will need to verify a few things first:
1. Is your Revit 2015 updated with the latest service packs?
2. Are you selecting the lighting fixture or the circuit itself? The Convert to ...Wire command will only show when you select the circuit itself. You can either hover your mouse over the lighting fixture, and press <TAB> untill the circuit highlights, or you can press F9 to activate your Systems Browser. You will now be able to verify whether the lighting fixture indeed has a circuit assigned to it.
http://revitrecess.blogspot.com/
Forma Design Contest
Technology Administrators
