Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
CHANGING THE SHARE COORDINATES
2 REPLIES 2
revitworkbench
293 Views, 2 Replies
Can you change the shared coordinates of a model that was previously built so that they go from the 0,0,0 starting coordinates to real world coordinates?
Michael
2 REPLIES 2
in reply to: revitworkbench
Yes. By moving the clipped Survey Point to the new location.
Hello @revitworkbench ,
I wanted to check in and see if the response from ToanDN helped. Additionally, the following resources may be helpful to you as well:
Feel free to select "Accept solution" if either response has been helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
Forma Design Contest
Technology Administrators
