Can you change the shared coordinates of a model that was previously built so that they go from the 0,0,0 starting coordinates to real world coordinates?
Michael
Hello @revitworkbench ,
I wanted to check in and see if the response from ToanDN helped. Additionally, the following resources may be helpful to you as well:
Feel free to select "Accept solution" if either response has been helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
