Hello everybody
I have a problem with my project...
I cant override the lineweitghts of all walls in my project. Some of then works some not... And i simply don't know what to do
I would be glad if somebody could help me.
Thank you all in advance!
Solved by ToanDN. Go to Solution.
The linked file does not have a phase called Existing
The views discipline is set to electrical.
SO it probably is something related to phasing... How could i fix that?
Thank you
What is the Phase and Phase Filter of the View?
And by the way, if the wall are cut then you need to change the Cut lineweight, not the Projection lineweight.
The Phase of the linked file is set to Reforma
Isn't there a way to remove all of the phases of a linked file quickly?
Thank you!
Select the link, edit type, then map the Phases of the link with the host. However, be aware that if you map them incorrectly, elements in the link may not show correctly, if at all.
