Cant override the thickness of a wall
Hello everybody
I have a problem with my project...
I cant override the lineweitghts of all walls in my project. Some of then works some not... And i simply don't know what to do
I would be glad if somebody could help me.
Thank you all in advance!
Replies (8)
Are they under existing/previous phase? What is the view's discipline?
The linked file does not have a phase called Existing
The views discipline is set to electrical.
SO it probably is something related to phasing... How could i fix that?
Thank you
Correct me if I'm wrong but I think Electric discipline always shows walls in halftone.
I think it does. But i don't know how that fact would change the lineweights of the walls
What is the Phase and Phase Filter of the View?
And by the way, if the wall are cut then you need to change the Cut lineweight, not the Projection lineweight.
The Phase of the linked file is set to Reforma
Isn't there a way to remove all of the phases of a linked file quickly?
Thank you!
Turns out i had to change the phase philter overriding...
Thank you!
Select the link, edit type, then map the Phases of the link with the host.  However, be aware that if you map them incorrectly, elements in the link may not show correctly, if at all.
