Is it possible to calculate the maximum value in a column (maximum value for one parameter in the schedule), and then use that maximum value in another column (new calculated parameter) to calculate something else? I found a workaround for calculating the sum of values in a column, and then using that in a calculation, (by calculating percentage, and then dividing the value by the percentage to get the total) but can't think of a similar way to do it with maximum.
I am working with a Space Schedule, trying to calculate the maximum value (worst case) for something, and then use that maximum to calculate something different.
Through the Revit UI? Probably not, pushing total sum into a calculated parameter via inverting the % of total is already more or less a magic trick (which doesn't work if any of the values are 0, fun!).
This leaves live automation through a third party add-in, or applied automation via something like a Dynamo script (execute script to update the parameter).
In the schedules, you can choose maximum and minimum in the calculation setting, but you can't use them in a formula.
Fábio Sato
