Revit MEP Forum
Cable Tray Colors
4 REPLIES 4
jpPJTFM
469 Views, 4 Replies
Cable Tray Colors
Is there a way that I can change the colors of 3 different cable trays to 3 different colors that will still display when I export to navisworks?
4 REPLIES 4
BiMBoXiT
in reply to: jpPJTFM
Hi.
The filter setting is the only option on Revit. or you can change the color settings on Navisworks.
if the cable tray has three different parameter values it helps to find and apply the color
Tool name " Find Item" through you can able to apply override color
BIM BOXIT
BiM BoXiT
Reed_Weinstock
You would need to assign a material to the cable tray or create a selection set in Navisworks. Navisworks only looks for materials, not filters or system overrides.
jpPJTFM
in reply to: Reed_Weinstock
Yes I see this will be the only option, thank you
jpPJTFM
in reply to: BiMBoXiT
Thank you this looks like the more efficient option
Forma Design Contest
