Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Angle fittings duct
8 REPLIES 8
Message 1 of 9
mzmaso90
397 Views, 8 Replies
Angle fittings duct
 I am trying to join these two duct, although its uncommon inclination angle junctions, Mep settings said that for fittings Revit will use every angle supported, due To this where I will conveil to change supported angles for specific angles?
8 REPLIES 8
Message 2 of 9
fabiosato
in reply to: mzmaso90
You need a tee fitting that supports angled connections.
Another option is to place a desirable shape fitting manually first.
Fábio Sato
Message 3 of 9
mzmaso90
in reply to: fabiosato
  1. I used a connection T with inclination angle standard ,but it is not as smooth as I supposed it would be. It has been adapteded just the duct inclinated but ducts connections are still separated. Do you know how to quickly modify its parameters for auto-adaptive t connection ?
Message 4 of 9
iainsavage
From your other post regarding the transition problem, you did not have the routing preferences properly populated for your duct types so I assume that you have been manually placing fittings and then trying to connect them.
If you populate the routing preferences with the preferred fittings then they will place and connect automatically.
Message 5 of 9
iainsavage
Video attached
Message 6 of 9
mzmaso90
Due to the fact that The inclination angle of the upper duct is  very uncommon ( 42,4475%)(coming from the cad drawing), Do you think it might be for this reason, that both ducts do not connect with each others?
Message 7 of 9
mzmaso90
in reply to: iainsavage
Hi there I reply to you before, in another response.
Message 8 of 9
iainsavage
Any angle should be possible if you have the correct fitting and the ducts meet.
Message 9 of 9
fabiosato
Different angle values may affect how ducts connect, I am not a duct designer, so I don´t have experience in so specific detail, sorry.
Fábio Sato
Forma Design Contest
Technology Administrators
