Revit MEP Forum
Additional HVAC Systems for Revit Energy Settings
2 REPLIES 2
ginmanM6FGZ
541 Views, 2 Replies
Hi all,
Is there any way to add additional HVAC Systems to the Advanced Energy Settings?
Under 'Analyze > Energy Settings > Advanced Energy Settings >  Buildings Data > HVAC System'  there are several choices, but not a full set of options.
For example, I'm modeling a school with radiant ceiling tiles only (no cooling), but there's no matching option.  Is there a way to add additional HVAC Systems to the energy settings?
And following that, is there a way to set the model as 'heating only'? Or is that something that would be done on the Energy Insight / Green Building Studio side?
2 REPLIES 2
iainsavage
in reply to: ginmanM6FGZ
You can set the Space conditions to be heating only:
Determines how heating and cooling loads are calculated. When set to Unconditioned, no loads are be calculated. When set to Heated, only heating loads are calculated; when set to Cooled, only cooling loads are calculated. All other settings contribute to the loads calculation.
You can select one of the following types:
  • Heated
  • Cooled
  • Heated and cooled
  • Unconditioned
  • Vented
  • Naturally vented only
ginmanM6FGZ
in reply to: iainsavage
Fantastic, thanks for that!
Forma Design Contest
