Hi all,
Is there any way to add additional HVAC Systems to the Advanced Energy Settings?
Under 'Analyze > Energy Settings > Advanced Energy Settings > Buildings Data > HVAC System' there are several choices, but not a full set of options.
For example, I'm modeling a school with radiant ceiling tiles only (no cooling), but there's no matching option. Is there a way to add additional HVAC Systems to the energy settings?
And following that, is there a way to set the model as 'heating only'? Or is that something that would be done on the Energy Insight / Green Building Studio side?
You can set the Space conditions to be heating only:
Determines how heating and cooling loads are calculated. When set to Unconditioned, no loads are be calculated. When set to Heated, only heating loads are calculated; when set to Cooled, only cooling loads are calculated. All other settings contribute to the loads calculation. You can select one of the following types:
