Revit MEP Forum
Adding new Sub-disciplines in Project Browser
21 REPLIES 21
Message 1 of 22
46119 Views, 21 Replies
Our firm has a seperate plumbing department who are hopping on to start modeling. However in Revit MEP, Plumbing is a sub-discipline to Mechanical. In our central file the Plumbing sub-tree has disappeared. How do I re-create one? I also need to create another sub-tree called "Fire Protection".
How do I create new discipline sub-trees in the project browser?? Thank you.
21 REPLIES 21
Message 21 of 22
scrosley
in reply to: KyleB_Autodesk
The sub-discipline option is greyed out and can not select
Message 22 of 22
ASCunningham
in reply to: scrosley
Most likely the view is being controlled by a view template. You can change this by modifying your view template settings or remove the view template all together from the view.
Forma Design Contest
Technology Administrators
