Adding new Sub-disciplines in Project Browser
Message 1 of 24
Our firm has a seperate plumbing department who are hopping on to start modeling. However in Revit MEP, Plumbing is a sub-discipline to Mechanical. In our central file the Plumbing sub-tree has disappeared. How do I re-create one? I also need to create another sub-tree called "Fire Protection".
How do I create new discipline sub-trees in the project browser?? Thank you.
Replies (23)
Message 21 of 24
scrosley
The sub-discipline option is greyed out and can not select
Message 22 of 24
ASCunningham
Most likely the view is being controlled by a view template. You can change this by modifying your view template settings or remove the view template all together from the view.
Message 23 of 24
jim.stephensRDE8Z
hi all
does anyone know how to create a sub-discipline off sheets, snipit attached
cheers
jim
Message 24 of 24
iainsavage
In Manage > Project Parameters find and edit the Sub-Discipline parameter and associate it with Sheets category.
 Parameter will then appear in the sheet's properties.
