add/remove pipe insulation hatch
editing collegues project and his all pipes with insulation are with hatch. I draw few new pipelines and it is without hatch. All pipes have to be the same with or without hatch. So how i can add or remove it?
NimeshJ
Hello @Anonymous ,
Kindly select pipe with hatch -> Edit Insulation (in pipe insulation panel) -> Check which type of insulation is used.
Now go to pipe without insulation -> Edit Insulation -> Select same type of insulation.
Please let me know if this works.
ye thats worked out!! thanks but is it possible to add those hatches by myself? or its insulation family?
NimeshJ
Yes, why not.
Now I guess these insulation hatches are controlled by filters.
Go to Visibility/Graphics Overrides -> filters -> find filter whose name maybe insulation or something related (or find filter which is having pattern and color as pipe insulation) -> Now you can give any Color, Pattern and Transparency.
Let me know if this is working for you.
