Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit MEP family
2 REPLIES 2
Dilip_K
280 Views, 2 Replies
Revit MEP family
I want REVIT MEP family according to Indian standards.Is it available or not and if available please share the link for the same.
Thank you
2 REPLIES 2
L.Maas
in reply to: Dilip_K
When installed there is an option to install different country libraries. India is one of them. See HERE for more information on how to install them or download it for your Revit version.
You should check your country websites and see if there is an organisation that maintains an Indian BIM standard and has content. Further you might check with local manufacturers if they have revit content according to your standards; And finally you can of course create your own families
Louis
Please mention Revit version, especially when uploading Revit files.
sujanc
If you have installed the revit version properly then you will get all the relevant template and libraries in the below location
"C:\ProgramData\Autodesk\RVT 2019\Libraries".
Please select "Accept solution" if the information was helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
