Visbility Setting to OPTIONALLY use formula
All to often, there is an object in a family that needs the visibility set to on (or off) based on the value of MORE THAN ONE parameter. To accomplish that, we need to create extra parameters creating a convoluted mess.
I want to be able to have the visibility setting be DIRECTLY CONTROLLED by a formula.
For example:
Select the object in question. Then select the little button for the Visibility setting (the one that brings up the list of Yes No Parameters).
This dialog box should be modified similar to the attached mock-up. The user can choose to enter a formula OR select a YN parameter.
P.S. It should accept any formula that returns a Boolean Yes or No.
5 Comments
doni49
Imagine these scenarios:
1) You have two different nested families in your family. You only want one or the other displayed. You create a single YN parameter called OptA.
Now the first nested family has its visibility set to the value of OptA (just like we would do it now). The second nested family would have its visibility set to Use Formula and the assigned formula would be Not(OptA).
2) Your family has THREE nested families. One or both of the first two nested families can be seen at a time but if neither are shown, the third one should be shown.
So the first fam would have its visibility set to Opt1, the second would be set to Opt2. The third would be set to Use Formula which would be And(not(Opt1),not(Opt2)). So now if neither one of the first two is shown, the third will be shown.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
sasha.crotty
sasha.crotty
