Transfer Project Standards without Opening Project
Bringing this up again as I think the original post was archived. I would like to be able to transfer project standards from a file that is not opened. It is cumbersome to always have to open a project or template first. This is especially true when you are transferring standards from a large project. Just need to add a drop down that says "From File" to search the directories for a file to transfer from and allow to select either an RVT or RTE file.
7 Comments
While they fix that, they should also allow for the fine tune selection of items that you want to transfer. Transfer Project Standards is like a sledge hammer for a tack.
krzystoff
It should function the same way, and perhaps integrate with, the Insert Views from File tool, with more granular options for selecting the particular components you want.
It should also have None unchecked by default, so users don't accidentally import everything, as they often do.
palm
TransferSingle does perfect job for us in similar situations
https://apps.autodesk.com/RVT/en/Detail/Index?id=1090472181312958476&appLang=en&os=Win64
Although in this add-in you'll have to open from-to files it's still a great tool, far better than the built-in
dennis_collin
Transfer Project Standards should workin my view in a similar way as the Designcentre does for AutoCAD.
Firstly it should work as the OP has stated, that you can access settings from another file even if it is not opened.
Secondly you should be able to 'cherry pick' specific styles  from a category list. In the same way you can selectively purge specific family types within the purge command.
Whilst add-ins are great the built in tool needs to be improved to make if more effective for system family transferal
dennis_collin
Just having a test on that Transfersingle add-in. Its great, and is a great improvement on the OOTB function.
Thanks for the heads-up palm!
dplumb_BWBR
Why do we need to open a family just to Transfer Project Standards from it?
I'd like to be able to TPS from a family in my Library without opening that family.
Would make importing standards much simpler.
lionel.kai
duplicate idea: Transfer Project Standards
