TOPOSURFACE SURFACE PATTERN
Please allow Topographical Surface Patterns.
When applying a surface pattern I get this error.
"Topographical surfaces do not support surface patterns. The surface pattern associated with this material will not be displayed on the indicated surface."
Topo / Site tools need to be progressed, desperately. Please add this feature.
Thank you for your consideration.
3 Comments
chrisBW22T
How is this not a thing, I want a coloured site plan and for some reason I have to used filled regions / detail lines which then dont show up in 3D. Revit is supposed to avoid duplication of work but topography not supporting fill / hatches forces you to still draw things multiple times for multiple purposes.
alix-hs
Everything in the title. Im thinking for exemple to grass hatch.
skyeg321
This is way overdue! We need to be able to see topo surface patterns in plan view.
Forma Design Contest
Technology Administrators
