Tagging 3D Elements after they have been Displaced
Would be nice if after 3D elements have been displaced they could be tagged again without having the reset the displacement set, tag the elements again, Displace the set again and then finally reorganize the tags.
Should just be able to take a 3D element after its been put into a displacement set.
3 Comments
I noticed that Revit does allow for displacement set items to be tagged as long as you are using Tag by Category Instead of Multi-Category Tags. the only problem with is this if I wanted to do tags for mark values they wont work properly in the displaced view.
Please Comment and like if you want this implemented I feel like this would add a lot of value to Revit.
peticid
Status changed to: Accepted
peticid
This feature was implemented in Revit 2023. Thank you for your contribution to improving Revit!
