A few releases a go we've got the possibility to rotate tags along a host trough the "rotate with component option".
However there should be possible to rotate the tag perpendicular to the host. One reason for this is to be able make drawing according to Swedish drawing standards (perhaps even other national standards)
An example of this is show in the attached image. A is a tag attached to a structural rebar as it should be according to our standards. B is a multi-rebar tag, but unfortunately the tag are attached to the spread line and not to the rebar.
