Sweep Length & Perimeter Parameters
Request: Include a parameter to extract the length of a sweep
Problem: Trying to complete a take-off for the length of sealant around uniquely shaped windows. For rectilinear windows, I can do twice the height + width but for arched windows or ellipse, there is not a simple formula. I'm proposing adding a parameter to provide the length of a sweep, such as that used for the window frame. This could be a read-only parameter to provide that info without affecting the family or modeled element.
This could be utilized in other functions like modeled-in-place walls sweeps (needed for sloped sweeps like the cornice on a gable wall).
2 Comments
Charles_Smith_ALTAM
Bonjour,
De mon point de vue, ce genre de paramètre est à créer directement dans la famille de fenêtre via un paramètre partagé.
Je pense également qu'il peut être calculé automatiquement dans Revit en utilisant des formules mathématiques classiques, qu'il s'agisse d'une forme cintrée et/ou elliptique (sous réserve évidemment que la famille de fenêtre soit paramétrable).
Auriez-vous un exemple ?
Bonne journée.
lschmitz56ZJU
You are correct that there could be a mathematical equation added to calculate the sweep length. However, this information is already available when editing the sweep (the length of each segment appears in the properties browser when selected). So I believe it's something that could be reported as a parameter rather than calculating it each time.
This isn't an issue that could be resolved with a single equation, nor is it applicable to just one family. This is information that already exists in the family (or component) but cannot be reported for an unknown reason.
