Structural Rebar - revert the recent tag change
Recent updates to Revit 2023 changes how tags work. This way, rebar tags will tag a single rebar, not the full rebar set. This is a serious downgrade that i want reverted back.
The main drawback of this change is that when you select the host of a rebar tag, you cannot hide, isolate, move, copy or otherwise modify the rebar. You're now reliant on third-party (or homebewed) addins in order to do simple tasks such as "hide all tagged rebars to see if you've tagged it all".
3 Comments
peticid
Hi Andreas,
In Revit 2023 we changed the behavior of tags pointing to rebar, because in that same version we introduced the multi-leader tags for rebar, which allows the selection all the bars that should be tagged at once. We would like to better understand your workflow and if the multi-leader tag or the multi-rebar annotation would be acceptable options for you.
In Revit 2024, we changed the behavior of the “Select Host” command, which now selects the entire set, not just the bar that’s actually tagged. Please let me know if this would be of help.
Kind regards,
Dan Peticila, M.Sc. Str. Eng.
Product Manager | Autodesk Revit
Joe1412
Community Visitor
Hello @peticid,
Is there any way to get this feature in Revit 2023 using Dynamo or Python? It will be very helpful to automate the tagging process.
peticid
Hi @Joe1412 ,
Adding multi-leader tags for rebar sets using scripts is doable. For Dynamo, you would require to create your own node(s) to tag subelements, as there are no standard ones for this step.
Kind regards,
