Structural Precast Update
Fix the issue where if you have the Structural Precast addin installed, this can cause an issue when change the properties of an object that the properties changes back to the previous value and does not keep the value.
4 Comments
peticid
Hi Kyle,
Could you please share more details related to the elements where you see the properties being reset? Are they elements used with the Precast for Revit app or other elements from the model, upon which no commands from the app were applied?
Kind regards,
Dan Peticila
Product Manager
DCP-BID-Structure
Autodesk, Inc.
www.autodesk.com
I thought I posted a link to the video showing the issue.
The elements are not from the Precast. They are all elements. It doesn't fully happy all the time, but when it starts, it doesn't stop until a restart of Revit or turning off the Precast. Even if the Precast app was not even used, it still checks the project to see if there is something it needs to do. This makes it hard to work when you are changing parameter values and it keeps changing back.
Here is a Screencast of the issue
http://autode.sk/2ptblLH
Best Regards,
Kyle Davis
peticid
Hi Kyle,
Thank you for sharing the details. We are going to take a closer look at this issue and improve this behavior.
Kind regards,
Dan Peticila
Product Manager
DCP-BID-Structure
Autodesk, Inc.
www.autodesk.com
peticid
Status changed to: Accepted
