There are times when wall do need to attach, but (at least the way we use Revit) walls are attached on a case by case basis. It is annoying to deal with the popup every time a floor is edited. There should be an option to never attach, and never ask (ideally in options and on the popup) to address the question "Would you like walls that go up to this floor's level to attach to its bottom?"
