Show only
Search instead for
Yes! This way we wouldn't have to have both working and printing schedules. The hidden fields would appear in the view but once you've put it on a sheet, they wouldn't appear there, but still appear in the schedule view itself. Wish I could vote for this one more than once.
This would make editing schedules a lot easier. Ideally, hidden columns would never show on sheets but we would have an option to toggle them on in the schedule view (halftoned for example).
Provide a formatting for fields to be hidden on sheets (but still viewable in the schedule view). Currently you can hide fields within schedules, but sometimes you want to be able to edit the hidden fields in the schedule view and not see them on the sheets. Current work around is to duplicate the schedule view for working and one for the sheet.
samuelsanf, I tried duplicating the schedule and working on it, but the problem is when I add a new parameter on working schedule , it don't appear on the one placed on sheet,
I was looking for an option where I can see the column in schedule always but it should not be visible when placed on sheet,
it will solve my problem of Hiding and Unhiding column again again.
It'd be nice if we had a 'temporary reveal hidden columns' button (similar to the lightbulb in the plans). This would be a mode that we could toggle on/off.
Yes! I totally back this idea, came by this thread searching for a solution to the tiresome duplicate schedules previously mentioned. Temporary hide/reveal would be great!
I control the order of sheets and disciplines in the Sheet List schedule -- General, Civil, Structural, then Architectural -- by using a hidden Sheet Order column.
It's a pain, when going back into the schedule editor, to have to unhide the Sheet Order column each time, make the changes, then hide it again. I propose that hidden columns be visible in the schedule editor, perhaps color-coded to indicate that they are hidden on the plotted sheet.
I always create to schedules for my sheet list, a working schedule that has all the parameters on and then a schedule that goes on the sheet. They are read the same info, so no duplicate work needed. I always edit the working one and just place the sheet one on the sheet as needed. Having the ability to have a "non-printing" column would be awesome though, save on the number of schedules for things like this.
@jamie_owens_Luminuat Having two schedules like a working schedule and duplicate schedule for the sheet is an okay work-around but it can be frustrating to manage especially with calculated and combined fields, and filters. I prefer to have a single schedule to manage. I would prefer an edit mode that shows all the fields and one that shows as it will actually display on sheet. Working with vertical text and other items is difficult to edit in the current edit mode.
