Sheet size in sheet list and title block
To assist in the management of sheets, we have a tradition of showing the sheet size in both title block and sheet list schedule. Either in mm (420*297) or in ISO size (A3). This is not something we can do in Revit, other than dancing with shared parameters, that can not read from parameters in the titleblock.
I would like to request that:
Project parameters "Sheet Width" and "Sheet Height" is added as parameters to the titleblock family, so that we can BOTH use them in labels AND in the family editor (to make a calculated value that change mm to ISO). Same parameters are added to the list of parameters we can apply in the Sheet list schedule.
We are given tho possiblity to add shared parameters to titleblock, so we do not have to fool around with project information hacks. In this case, I would use the parameter to calculate from mm to ISO. Other need could apply.
9 Comments
henrique.sanson
Following up on that, I was about to post the following suggestion when came across yours:
If possible, to add Title Block parameters to Sheet Schedule fields, then one would be able to control visibility/dimensions parameters through the Sheet Schedule, making it much easier to coordinate. Or inversely, being able to label the correspondent sheet instance parameters inside Title Block families.
Good Idea..in properties of ttlb we see those parameters but not in labels from ttlb....strange
Great idea! Please, add this functionality to revit.
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
 The Factory
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | Sheet List Schedules Enhancements | Autodesk
 -The Factory
Ric_Weber
@kimberly_fuhrman-jones I'm missing one piece of this idea and that it the ability to use the Sheet Width and Sheet Height parameters within the title block family to create a label...  I am not seeing those parameters in my title block family...  Am I missing this capability somewhere that I'm not finding?
Ric_Weber
this was meant for a different idea I think.  Not sure what happened.
@Ric_Weber , Looking into it, but I think you are correct. The parameters are built-in, so they are not available to be added to labels in title blocks, only sheet lists. This should be a separate idea.
Ric_Weber
I have created the part about labels in title block families as it's own separate idea.  Please vote it up!
https://forums.autodesk.com/t5/revit-ideas/use-sheet-height-amp-sheet-width-in-label-in-title-block-...
