Shared Parameter support thru A360?
We are working with multiple consultants and a partner architecture firm and need to be able to share our shared parameters through A360.  The only way to do this currently is to upload to A360, and each individual firm has to download and place on their network, and then point to the file.  Can we just point to the file on A360?  Same scenario for keynote file, would help with collaboration immensely to be able to share these files live the way we are sharing our models.
6 Comments
I believe once Alexandria is fully integrated- we will have that capability : )  Good post!
Ian.Ceicys
Ian.Ceicys
Status changed to: Accepted
Ian.Ceicys
if you have desktop connector you can navigate to your BIM Team folder in your user directory and open the shared parameters file that way if it is saved into your BIM360 site.
FYI
Ric_Weber
The ability to put and use a keynote file on ACC would be FANTASTIC!!!! Hopefully it wouldn't even need to be done through DC, but just in ACC like the models!
