In the filters window where we create or modify filters, it would be useful to have the possibility to set the default visibility/graphic overrides for each filters.
Then when we add a filter into a view template, it already has the visibility, lines, patterns, transparency and halftone parameters filled by default.
This way if we add the same filter inside many templates, we would always have the same graphics associated instead of setting those parameters again and again inside each template (And we could still modify them after in the Visibility/Graphics box if we want them to look different than the default parameters).
Thanks.
