Select Multiple Views to place on Sheet
Develop a function that makes it possible to select more than one View to put on a Sheet.
Alignment can be done later.
If possible, create a alignment tool as well.
3 Comments
Good idea. In particular, I would like to point out that Adobe InDesign does something similar really well. In InDesign you can load multiple files for placement on your page. When multiple files are loaded the cursor changes to "loaded cursor" that has an numerical indicator of how many files you're about to place on your page. As you place the files they appear on the page and the numeric indicator in the cursor decrements. You can cancel placement at any time by pressing escape.
This is related to https://forums.autodesk.com/t5/revit-ideas/move-multiple-views-between-sheets/idi-p/7811005
We are pleased to say that this has been implemented in Revit 2024! Thank you for your contribution to improving Revit!
Help | Place Multiple Views and Schedules | Autodesk
 -The Factory
