Show only
Search instead for
Of course I can. But it is an idea to make it easier and I ask why the menu is disable in group edit mode. The problem is, sometimes when you select elements out of editing mode of group and then you are going to change to something else it will be ungrouped. Not all the times but sometimes and this is why I ask for enabling this feature in edit group mode.
More enhanced functionality in group edit mode would be good too... for instance, one cannot create a duct from a connector like one can in regular modeling mode.
I found a limited workaround. Once in the group use the mouse to select everything, then use the filters to filter out everything you do not want. This still has the limits of what you can filter out with the multi-select tool.
