Allow us to use different setting in the ''Stair Type Properties'' and ''Stair Calculator'' for the ''Maximum Riser Height'' and ''Minimum Tread Depth''
This way we could set the value we want our stair to be calculated with and keep those minimum and maximum critical values for code compliancy as a simple warning.
Now our stair ''Maximum Riser'' and Minimum Tread'' are normaly set to a more ergonomic value for calculation (so not really a max/min) and we get a warning each time we want to go up to maximum or down to minimum + We have no way to set the real maximum and minimum inside the family.
If i go the other way arround and set the real maximum/minimum, then I'll alway have a default weard non-ergonomic ratio stair...
