Revit Panel Schedules
Revit panels need a feed through option. There are times when a single panel has in excess of 200-250 circuits and 2-3 panel sections are required. These panels need to have numbering that is continuous, and load sums and diversities at the first section. This a very basic engineering practice used on many projects. At least give users the opportunity to specify a start number for the circuit numbering. We could create a semi-manageable work-around from that while the rest of the changes are made.
6 Comments
aaron.jonesSAP83
If you like this, please vote on the idea that already addresses this.  Autodesk is more likely to notice one idea that has several votes than multiple, repeated ideas.
https://forums.autodesk.com/t5/revit-ideas/panelboard-ftl-electrical-revit-mep-for-multisection-pane...
Martin__Schmid
Status changed to: Accepted
Thank you for submitting your idea, and the comments posted thus far.  We are marking this idea as accepted, and are investigating some improvements related to this.  If you would like to provide further feedback on these capabilities, we would be happy to involve you in our beta program (Revit Preview).  Reach out to revit.preview.access@autodesk.com to join!
Martin__Schmid
Hi -- thanks for the idea, and for those of you that participated in our preview program on this. This request is being marked as Implemented, as the request is now delivered in Revit 2020.
If after you've had a chance to utilize the new functionality there are additional capabilities you are looking for, please create new Ideas for each item so they may be voted on independently to provide us some measure of importance and priority.
Tarek_K
Status changed to: Gathering Support
aaron.jonesSAP83
@Tarek_K I believe this has been fully implemented.  Is there a reason it's been re-opened?
Tarek_K
Forma Design Contest
Technology Administrators
