Problem Revit 2027 removed the contextual Options Bar that appeared while placing walls and other architectural creation tools. In previous versions, the parameters changed most often during placement sat in one fixed row directly below the Ribbon: Location Line (Wall Centerline, Core Centerline, Finish Face Exterior/Interior, Core Face Exterior/Interior) Height / Depth and the level selector Chain Offset Radius These values are now split between the Ribbon and the Properties palette. Parameters that were adjacent are scattered, and the ones in Properties are no longer in a fixed screen position. A companion idea covers the same removal for MEP creation tools: Restore the contextual Options Bar for MEP creation tools (Pipe, Duct, Conduit & Cable Tray). This idea is filed separately because the MEP one is tagged to pipe, duct, conduit and cable tray, and architectural users searching for wall placement issues will not find it. The affected population is larger than either thread shows on its own. Impact Laying out a floor plate means switching location line constantly. Core centerline for structural coordination, finish face for dimension strings, core face for partition layout, often several times within a single wall chain. I parsed my own Revit journal files to measure this rather than estimate it. On one small residential project in 2027, wall-heavy work: 231 Properties palette round trips across 11.5 hours of active modeling. Twenty per hour. That is one project, not a controlled study, but those are logged events, and every one of them is a trip the Options Bar previously absorbed inside the live command. The two controls are not interchangeable, which is why "these were duplicates" does not describe what changed: The Options Bar was command-scoped. It appeared because a command was running, occupied a fixed single-row position, and accepted changes inside the live command without ending it. Muscle memory worked because the target never moved. Properties is selection-scoped. It is a variable-height list whose field positions shift with element type and scroll state. There is no fixed target to learn, and values are set before or after a command rather than during it. Autodesk support's own published workaround for a related case makes the difference explicit: assign a keyboard shortcut, and confirm the value has been applied in Properties before entering the shortcut. That confirmation step did not exist when the value lived in the Options Bar. The supported workflow now contains the extra step. Suggestion Restore the contextual Options Bar for wall and architectural creation tools, or add a user preference that re-enables it. Shipping it off by default, as a checkbox alongside the other interface options, would satisfy both audiences. New users get the interface as designed. Production users turn it back on and keep working at speed. The code shipped in 2026, so this is a restoration rather than new development. Summary This is not a request for a new feature and it is not attachment to an old button position. It is a measured productivity regression on the single most frequent adjustment in architectural modeling. Twenty interruptions per hour, from my own logs, on the work that produces the drawings. An optional toggle preserves the new UI direction and returns the workflow to the people who model all day.
