When I batch print single sheet PDF, Revit normally would use Alpha numeric to plot in sequence. If I have sheets start from G-xxx, the dialog will always print at the bottom while Architectural set A-xxx always print first. It would be nice to have a button that allows user to move the sheet up and down the list. That way Revit will print base on custom sequence.
