it would be great to have the possibility to add more than one shared parameter at once inside families.
In my firm I am using nested families and every time we start a new project with new clients I need to add new information through text parameters. To do so, I must change my shared parameters in every sub-component of all nested families in order to have the possibility to associate them. Having the possibility to add several shared parameters at once in a sub component will drastically reduce the amount of time that I usually spend during this task.
Please note that it is not possible to add those parameters inside the project as "project parameters" because in that case the parameters will be attached only to the nested family but not to all the sub components... Which is not what I need for my scheduling purposes.
Thanks for your attention. Regards.
