PDF export settings
PDF export settings
It would be very useful to be able to save PDF export settings across all Revit projects to set company printing standards without the need to 'transfer project settings' each time every for new project.
3 Comments
RobDBrown
Orsolya.Balazs
Autodesk Support
Let me register the following wish on behalf of a customer from DACH region:
Currently it is possible to save the options in PDF Export dialog within a Revit session/ file. The enhancement request would be to be able to transfer (export/ import) those settings between various files as well.
Tags (5)
Ric_Weber
For future use, those items that can be saved to an Export Setup could be saved to your project template(s) or starter files.  Isn't that enough.  If you get those put into your template, you should be good to go?
