There needs to be a way to control the offset of the Path of Travel lines around obstacles. Codes like NFPA 101 specify that when measuring Travel Path distances we must account for a minimum 12" offset from the edge of any obstacle. I do not currently see a way to control this in the Route Analysis Settings and do not see a clear indication in the Simulex engine of how this could be handled.
The only indication I see in this Autodesk Knowledge Article is that the Simulex engine does indeed offset for an "optimal walking path". We need better control of this offset to ensure our code requirements can be met.
