This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Option to show stairs in true representation in RCP views
Sometimes when you are designing a grand staircase, it is useful to document the underside of the stair.  Currently, there is no good way to display an accurate representation of a stair's underside in an RCP view.  I propose that an option be added to a stair's type properties that toggles between traditional RCP view or actual accurate representation of the modeled stair in RCP view.
15 Comments
matt.hand52
Upvoted. I'm actually surprised this is still an issue considering how far back this issue dates. I would be interested to hear if there is any "official" explanation as to why Revit hides stair elements when in an Reflected Ceiling Plan, or why they are specifically avoiding addressing this gap.
It should be possible via transparency or other means to allow treads and landings to be visible in an RCP. If you tab-select a stair, you can actually cycle through the various pieces and select them, but they can only display temporarily. This is what we want to see! Even if there was a subcategory of whatever is masking the bottom of the stair to be able to turn off, that would work. In this case, this a stair in the middle of a space, not having a door to a "stairwell" makes it very ambiguous as to what direction the stair is going or if there are intermediate landings on this level that require lighting.
Ahmed_Muharram
Can you please make hidden lines for Stairs in STR plans looking up.
RDAOU
I think Plan Region + a Filter works just fine
matt.hand52
@RDAOU Could you share more details of your scheme?
RDAOU
@matt.hand52
Since it is an UP view, Set the view range of the crop region to the level  below stair with depth unlimited...this should show u the riser/tread ... add a filter to override stairs in  view to hidden/dashed.
matt.hand52
@RDAOU
Okay that does indeed work to show the stair in the way that we would want. The problem then is just how that effects presentation of MEP Elements that we need to show around the stair. The output from that solution puts all elements within that region to the "<Beyond>" Line style regardless of if it is above or below the stair, they all will appear the same:
Since this is an "Up" View, the element above the stair should be showing as <Beyond>/Hidden while the fixture below the stair should be full tone; if you were looking up from under the stair, that is the first thing you would see. Moving a fixture outside the Plan Region shows it as full tone, but this is the one I want to show Hidden being above the stair landing:
So it is a nice workaround Architecturally perhaps, but we need to get this exact stair presentation without the Plan region, then these elements should show correctly. That's pointing at ADesk, not you RDAOU 😁
mpukas
I'm struggling with this topic. I've been trying @RDAOU's method of using a plan region, but it's not working for me. The <Above> Supports on each side and the <Above> Outlines are visible, but not the treads & risers or any other part of the stair. The run of the stair will high-light for pre-select when the cursor moves over any tread/riser and I can select it, but I can't do anything to do it - can't change VG is any manner. I can also select the stair itself as in any other view, but the treads/risers of the run are not visible in either pre-selection or selection.
Plan region should be setup like this:
Primary range:
- Top: at bottom of stairs
- Cut plane: below stairs
- Bottom: same as Cut plane
View Depth: above top of stair
mpukas
@ToanDN - Thanks for the reply. I did not have the Top set correctly. Changing it to the bottom of stairs, instead of above the top of the stairs, makes the stair visible. Thank you!!!
mromagnoli
sahibZLTGS
@ToanDN
I tried to set up the plan region view range the way you said but the stairs still don't show.
If I make the cut plane any lower everything turns black.
mpukas
Ensure the offsets from the lower floor are at the same height that the stair starts from the level. In my projects, I have finished floors that are anywhere from 0.5" to 2.25" above the level, and that's the height that I start the stairs.
I've given up on this method, even though ToanDN's suggestion works. There are still a couple of major drawbacks and PIA aspects to trying to achieve this. One being the stairs cannot be made transparent within the viewport (at least I can't make them transparent) and they hide any light place directly above. Without the viewport, lights above are visible. I now use detail lines to represent the stair treads.
_dalewfd
+1, please let us see the stairs properly in RCPs (including railings).
ODP_MED_DCadena
@sahibZLTGS Check the stair type is a assembled stair and it has treads assigned to it, I proved several types and this is the only configuration where the View region works.
DavidWoodCT
Yes, it would be good to have the option to switch off each of the visibility 'quirks' (such as this, and 'short walls') so we could start with a clean view of the model.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
