This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Non-level Datum Tags
Without creating a level, I would like to be able tag an object's elevation in section. For example, the ability to call out the bottom elevation of a beam in a wall section without adding a level is useful, especially when it is an anomaly or critical to the design. Currently, I use a dummy tag for these items.
3 Comments
Lachlan-JWP
Doesn't the spot elevation tool do this?
stanfordG8BUY
True but I would like to use the same elevation tag used for levels. Graphically, it is easier to read the various elevations when they are all in the same format. Essential I want a spot elevation to look like the level tag with ability to add a name on the top line with the elevation on the second.
Lachlan-JWP
You can use your level head as a spot elevation symbol. Just edit it and change it's category. I can't think of an easy to format the text the way you want though. I think that might be worth asking for.
