NO MORE PARAMETER TYPES
Stop the nonsense, no more shared or project parameters. One type does it all! You should be able to use project parameters across projects and key shared parameters. If there is a name conflict, just request new name or replace parameter message.
Simplify Revit! That should be the new Autodesk moto!
3 Comments
Yien_Chao
It won’t happen.
Programmatically speaking, each Revit objets has its own attributes and inherited the attributes (parameters) of the higher hierarchies classes.
When you add shared parameters, you create attributes externally and made it available to others families ( that’s why it is called shared parameters).
Basically, You are asking Autodesk to rewrite the entire software.
It also doesn’t make sense for me when i started, but i get used to it. and through programming, with Python or C#, you will see that Revit is an object oriented based software.
Sorry Yien Chao for the late response, I was out of town enjoying my vacation! and thank you for your comment.
I believe I understand how parameter types work. What I am suggesting to Autodesk is to make parameter types more user-friendly. Currently, shared and project parameters have separate menus, and to create/manage these there are a LOT of clicks involved. Im my opinion, it needs to be simplified. In Revit (I use 2017 version), the differences between parameter types are minimal, and if these are ironed out it could just be a checkbox to switch from shared to project parameter. Modifying a .txt file should not be a problem.
Moreover, to simplify Parameter Management Autodesk could do things such as:
- more visual menus. Maybe even different visualizations (tree-structure, color coding...whatever helps)
- Simplify changing parameters' attributes. Allow drag and drop style (allowing multiple selection).  A lot of parameters make no changes on the model but changing these is just as cumbersome as changing geometry parameters (changing parameters that involve text or numbers should be a lot easier/faster)
-  Help the user organize parameters. Help the user homogenize parameters across multiple families, find and fix duplicate parameters, naming aids, etc. Improve edit and transfer of parameters attributes to families loaded.
Like any BIM software, Revit's objective is to improve project management, drafting, and coordination. However, Revit is very old-fashioned and slow in terms of internal management of the model and its parameters. It just needs to be better at its primary objective as a software.
Alex
To get rid of shared parameters would actually be really simple to program. Autodesk simply need to:
1. Expose the GUID of all parameters. e.g. add it to the parameters as a read-only line in the properties box, perhaps under Identity Data.
2. Allow paste of GUID into families when creating parameters. Same in project when creating Project Parameters.
3. Publish a standard set of GUIDs such as ANZRS has done.
4. Actually use that published list consistently for all OOTB families.
Shared parameters are simply a crude workaround for getting the GUID consistent between projects and families.
