More Layer Priorities in Wall Editor
It is not possible to have wall types join appropriately on simple and complex projects without more layer priorities.
Add, Structure 1- Structure 2 Structure 3 etc....
A very simple example:
If an exterior wall has studs in its core properly disallowing interior walls from piercing this core, it will have to remove these walls from the core, or at the least, reduce the priority, when it intersects the roof and requires the parts of the latter's core to supersede the latter.  (No switching join order will not work, the wall is too complex.)
Lowering the priority of other walls will also not work as these have complex joins of their own.
2 Comments
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
 The Factory
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | Customize Layer Priority in a Compound Structure | Autodesk
 -The Factory
