Missing Revit Feature: Auto‑Sequence Phasing
Summary Revit locks phases into a fixed chronological order that cannot be changed after creation. Real projects—especially data centers, utilities, and healthcare renovations—frequently require resequencing due to commissioning paths, outage windows, equipment delays, or field conditions. Today, teams must rebuild phases manually, reassign elements, and repair views and schedules.
Request: Add a native capability to reorder phases safely and automatically.
🎥 Video Explanation: I walk through this missing feature, why it matters, and how Auto‑Sequence Phasing would work: https://youtu.be/PQb8OvfRn68
Problem “Revit enforces a fixed phase order that cannot be programmatically or interactively reordered after creation.”
This causes:
  • Large amounts of rework
  • Broken phase filters, views, and schedules
  • Misalignment between model and real construction sequence
  • Reduced trust in Revit for 4D or execution‑driven workflows
Proposed Solution: Auto‑Sequence Phasing Enable dynamic phase reordering with automated updates to all dependent data.
Key Requirements
  • Drag‑and‑drop phase reordering
  • Automatic remapping of Phase Created / Phase Demolished
  • Safe updates to phase filters, view templates, schedules, and sheets
  • Preview/audit mode before committing changes
  • API support for automation
  • Consistent behavior for linked models
Why It Matters This is a core data model limitation, not a workflow tweak. Utilities validate the need; data centers amplify it.
Benefits:
  • Eliminates manual phase rebuilds
  • Reduces documentation churn
  • Maintains 4D alignment when sequencing changes
  • Improves as‑built accuracy
  • Expands Revit’s value in sequencing‑driven industries
4 Comments
Ric_Weber
Charles_Smith_ALTAM
Bonjour,
De mon point de vue, la solution serait de modifier Revit afin qu'il ne gère plus un projet composé de phases successives mais plutôt avec une multitudes de tâches.
Le top serait qu'Autodesk remplace définitivement les "Phases" par un "TimeLiner" sur le même principe que Navisworks, ça serait vraiment le top. Il serait géré par un planning provenant de différents logiciels.
J'ai déjà réalisé une demande sur ce thème. Mes projets comptent des centaines de tâches. Il est vrai qu'en l'état actuel des choses, c'est un casse-tête fastidieux et interminable pour mettre à jour les modèles dès que le planning change.
@autodesk : Stop aux séquençages ! Faites de Revit un vrai outil 4D avec lequel on pourra en extraire des livrables sur papier et pas seulement des vidéos !!!  😎
I really like your point of view here and it hits on something a lot of us deal with.
At the end of the day, we just need more flexibility. Sometimes we’re working with phased construction packages tied to a schedule, and other times everything shifts around outages and field constraints, so it turns into a sequence of tasks instead. Revit should be able to handle both without forcing us into one way of working.
Tying the model to tasks through something like a TimeLiner approach would make a big difference. It lines up much better with how projects actually happen in the real world.
More than anything, this needs to stay flexible. And being able to connect to schedules from multiple platforms is going to be key if this is ever going to be truly useful in Revit.
J’apprécie vraiment ton point de vue ici, et ça met le doigt sur quelque chose auquel beaucoup d’entre nous sont confrontés.
Au final, ce dont nous avons besoin, c’est davantage de flexibilité. Parfois, on travaille avec des phases ou des lots de construction liés à un planning, et à d’autres moments tout évolue en fonction des arrêts et des contraintes terrain, ce qui devient alors plutôt une succession de tâches. Revit devrait être capable de gérer ces deux approches sans nous imposer une seule manière de travailler.
Pouvoir relier le modèle à des tâches via une approche de type TimeLiner ferait une vraie différence. Cela correspond beaucoup mieux à la façon dont les projets se déroulent réellement sur le terrain.
Plus que tout, cela doit rester flexible. Et la capacité de se connecter à des plannings provenant de différentes plateformes sera essentielle pour que cette fonctionnalité devienne réellement utile dans Revit.
Charles_Smith_ALTAM
Espérons qu'Autodesk en tienne compte lors de la mise à niveau de leur version. Mais il semblerait qu'ils soient très long à la détente...
