Keep text horizontal on Elevation Marker
Similar to the Section Header, allow the elevation marker to keep the text horizontal. The current solution to this does not work properly as it is only for use with a single type of label with multiple lines for the detail and sheet number parameters. This limits flexibility for other standards. For example, see the following image
