Real Finish Materials on Rooms Schedules
In rooms schedules you can specify parameters for Base Finish, Ceiling Finish, Wall Finish and Floor Finish; But this don't affect the model, only schedules and tags. Thats's not so BIM.
I would like to see, in the forthcoming versions of Revit, an Instance Parameter on Walls, Floors, Bases and Ceiling that control therir Finishes, a Parameter that can be controlled through the Rooms Schedules.
Walls should have a parameter of these on each exterior and interior faces, at least; but better if the wall faces splits on every room and take a finish "defined by room" or their default finish if the room do not have one. This would save a lot of time of spliting surfaces, and gift you a more real and quantifiable model.
It's OK to have, for example, different Types of walls, even if you only change the finish materials; the paint in one face or the wallpaper textura or the color of the carpet in a floor... at the end you can have a Quantity Takeoff to sumarize the materials in a precise way. But in Wall or Floor Schedules you will have separate types that are practically the same type; in tables that you only want to show structure materials or dimensions, you like to have to types of and element classify only for de paint color.
25 Comments
It's 2025, and Revit 2026 still doesn’t offer a native way to report materials on ceilings, floors, and walls by room. This has been a long-standing limitation, and it’s surprising that after all these years, there's still no built-in solution for this essential feature.
Meanwhile, Archicad has had this capability for years. It's time Revit caught up.
g_demartinoD3ZGE
Get faces toward the space's centroid or toward the space. Only faces related to a space or room or other
Tags (1)
samuelsanf
There are material "<By Category>", should be possible to create material "<By Room: Base Finish>", "<By Room: Ceiling Finish>", "<By Room: Wall Finish North>", "<By Room: Wall Finish East>", "<By Room: Wall Finish South>", "<By Room: Wall Finish West>" (using Project North for reference), "<By Room: Floor Finish>".
ELeonard
Currently in Revit, the paint tool applies continuously across an entire wall face, even when that wall intersects with other walls and creates separate rooms/spaces. Because of this, users must manually use Split Face/split wall every time adjacent rooms require different wall finishes or paint colors.
Make wall paint behavior "room-aware"
When a wall intersects another wall and creates distinct room boundaries or separated wall faces, Revit should automatically recognize these as independent paint regions. Painting one room side surface should stop at the room boundary/intersection instead of continuing through connected faces into adjacent rooms. This would significantly reduce repetitive modeling steps and improve workflow efficiency for architects and interior designers working on finish plans.
Example:
If two bedrooms share one continuous wall but require different paint colors, painting Bedroom A's side should not carry through into Bedroom B's wall face. Revit should automatically stop the painted region at the room separation/intersection.
This small change would remove thousands of unnecessary split face operations across production projects.
Tags (5)
samuelsanf
