I would like to be able to hide certain revisions, that arent ready to be issued from the index sheet.
Why would this be needed.
Bid packs, Bulletins/Addendumns are all tracked by the revisions manager. Quite often a Project Change Order will come in that requires work to be started in an area that requires tracking through revisions. This work quite often happens parallel with other work for the project.
If other issues have to go out prior to the completion of the PCO, then it is undesireable for the unfinished revisions to show up in the title block or in sheet indexes. Currently the only way to get around this is to temporarily delete the revision clouds, Print then Undo the deletion to get them back.
It would be nice to have an extra check box in the "sheet Issues/Revisions" manager so it can be checked as "Future" or "Not Issued". You could facilitate this by having "Not issued" clouds show up half tone without any entry appearing in the title block or index sheets. The previously issued revision would then show up in the index sheet letting the contractor know what version of the sheet is current.
