Have isolated footings that are cut in plan view display as cut.
Currently, an isolated footing that is cut in plan view still displays as projection.  So, a 30' deep caisson (at level 1), next to a basement wall still displays as projection, rather than displaying as cut.  A work-around is to add a wall, join the caisson to the wall, then delete the wall.  The caisson will remain displaying as cut in all views.
Personally, I think this is a bug, but I'm told by support that this would be an enhancement and needs votes before it will get any attention.
3 Comments
lmpka
Just to clarify, a 30' caisson at level 1, that you would expect to display as cut at the basement level, still displays as projection at the basement level, unless you join it to a wall.  Adding a temporary wall, joining it to the wall, then deleting the wall is a work-around to get it to display correctly.
Nurlan-A.
Structural Foundations is cuttable family category.
lmpka
I'm not sure what your point is. They still don't display as cut by default.
