Enhance element ID functions
Element ID's can be useful for locating elements in the model.  However, they are cumbersome to use,  Suggestion is to show the element IDs in the instance properties of the element.  This could be a new category in the instance properties, such as 'More' or 'Advanced'.  This section might even include warnings that the element is generating.
30 Comments
muhammetkapici
I hope Autodesk interested my idea 🙂   I would like see  that info of ``Element ID`` on Properties Palet for all elements also we can use this parameter during arange any schedule.
Still I am using some add in as below link. But it is not working sometimes.
https://apps.autodesk.com/RVT/en/Detail/Index?id=2520243821032981522&appLang=en&os=Win32_64
Tags (1)
I think it will be much better to add the "element ID" to the instant properties for each item , other than existing in a separate icon at the  "modify tab" .
As this info. ( element ID) is needed in some cases after linking files and need to know ID of item in the linked file , but we cannot get unless open the linking file itself.
But it will be much useful to get this info once tabbing on the item to be selected from the link and to get the ID from its "Instant parameters".
Tags (2)
GTisRuleX
Revit has a severe lack of being able to locate items relatively quickly in a project.  I would request that the Element ID is turned on as a schedulable parameter.  (Specifically on MEP objects, I'm sure it would help the Arch/Structure guys.)
This would give the ability to generate 1 schedule with element ID turned on, screenshot it, and locate items thru the project that need addressing, instead of constantly returning to the schedule to use "Find Items" which is a bit of a slow process one item at a time.
Unfortunately Element Ids are not stable. In a worshared environment in
particular, element ids will shuffle and the element to which they
previously referred will no longer be the same element after reload latest
or sync with central.
Unique Id is the only stable (within one project) representation
(identifier) of the element.
That said, you are free to create your own shared parameter on all element
categories and fill it up with the element id via the API directly or
Dynamo.
Basam.Yousif
These important items of information need to be converted into properties, and listed on the standard palette. Also, they need to be made available for scheduling. You really can do this. It's not hard 😉
GTisRuleX
Dynamo does a lot of things for us, but it can be a real headache with work sharing as well. Well what about exposing the unique identifier? Something we can use to track parts that's already nested on families for quarry?
GTisRuleX
You'd have to give us a way, like "Find Items" as well.
d-denton
There's an app for that. And its free.
@d-denton - This reply has been edited by the moderation team as the legacy links were no longer valid
GTisRuleX
Come on guys, we're getting off topic.  Adding additional apps across multiple users isn't a good solution from an administration standpoint.  The information is already available on the parts, Autodesk just needs to expose them to scheduling.  The original post isn't a 3rd party application, or custom coding ran by a 3rd party application (Dynamo.)  I also speak from an administration standpoint, not just speaking for myself but a company of users that would all like a similar tool.
Been using Revit coming up on a decade, and there's ENOUGH work arounds, add ons, and patches for a lifetime.
Ever submit a ticket to Autodesk support?
"Is it your add ons?" "Well we can't help diagnose why your project browser is crashing opening a view because you have Autosection installed."  "Please revert to a clean installation of Revit, try your issue again, and if it still persists respond to this ticket #".
A_MAQ
In schedule , it will be very useful that ID of elements can be inserted to schedule parameter
very greet idea and to be shown also in property panel
A_MAQ
Yes it is
Good idea....if you need it now you have in you tube how you can do it with the dynamo...
Yes, this would be a very helpful feature to have. I'm assuming that dcesko's dynamo script is copying the elements ID to another parameter, which provides you with the information you need, but it's a bit redundant and we should have to do it. It should just be available to us directly.
A_MAQ
i really glad to here that , not only me need this feature
keep voting
A_MAQ
 we need support for this important idea
 For more clarification,,,
brady0542
I think the idea of having apps and scripts is what makes things so powerful. everyone uses software for their purposes so Revit gives us a basic platform to model buildings and collaborate with one another. Depending on what your scope of work is you need it to different things. the beauty of a central model is that only one person needs to have the add-in if you are just filling in parameter data. Then all they do is sync and everyone else has it.
andre.abotnes
Why not have each elements element ID in a read only parameter? Would be helpful for coordination.
Tags (1)
