I do both electrical design and construction coordination. It would be a huge benefit to have the default systems changed for the conduit service type parameter, i.e, Normal, Emergency, Critical, Life Safety, UPS, etc., the ability to add additional systems as needed, similar to what is done on the M&P side and have these properties transfer to Navisworks for easy filtering.
I know you can change the radius of a conduit bend to simulate an underground sweep that is very commonly done, can you add an option or systems conduit that works like a spline so we can add in these large sweeps. This would save a ton of time modifying a huge network of direct bury conduit by eliminating the elbows that at time generate errors when using the multi conduit tool.
Also, I used the mechanical duct when doing site work, can we add a duct bank systems family for the electrical side? Duct bank does not function like mech duct and I have to use a filter when identifying the different site systems. I do very large medium voltage projects, so this would be a huge help with coordination and usability.
