Easily change hosted family to non hosted family
I would like the ability to be able to turn off and on element hosting in the family editor.
Say change a door family that hosts into a wall into one that can be placed anywhere.
This should be a check box in the family editor.
26 Comments
jkarben
Ideally this would also include changing the orientation of the family too. Example: changing a faced based electrical wall panel, which is modeled horizontally, to the vertical position and make it un-hosted.
mayurpawar082
Community Visitor
We can do it for some hosts not all.
emmanoelneri
It would be really cool to change the host of an existing family. For example: transform wall-based(ceiling...) families in face-based family. Or even in non-hosted families
Tags (1)
bimarqasia008
Community Visitor
Well, in version 2023 Autodesk has still not bothered to respond. They don't have to, because you don't have a choice but to use their product.
ks2_wmb
All I want is to be able to Copy/Monitor every single category.  When I convert my Casework family into a Light Fixtures family, I lose all the subcategories that I've assigned.
https://www.revit.news/2016/07/converting-wall-based-casework-to-face-based-in-revit/
ks2_wmb
Okay, so what I did yesterday to convert my casework families:
  1. I nested my wall-hosted casework inside of a wall-hosted light fixture family.
  2. I loaded the light fixture outer family into a small dummy project
  3. I loaded that project into an empty project
  4. I used copy/monitor to convert my outer light fixture family to a face-hosted family
  5. The nested casework families were also converted to face-hosted.
The common wisdom here is to convert your casework families directly to light fixtures, but then you lose the subcategory assignments of the family elements.  Using casework families nested inside a light fixture family, the casework families kept their subcategory assignments.
Forma Design Contest
