Draw at Midpoint
Draw at Midpoint
Please provide an option (for walls, lines, etc) to draw at midpoint.
You could start the function, then select the two parallel walls or lines, and a wall or line would be created matching the extent of the original objects, and of the type in the type type properties. This opens the door to then have multiple segments. So you could change the option from 1 line to 6, etc.
Thank you for your consideration.
1 Comment
Do you mean like the autocad function?
I would like that function, that way I don't have to give everything and dimension anymore. Also the from option would be helpful to draw quicker.
