Disable holes in "Area reinforcement"
"Area reinforcement" automatically cuts openings in the rebars, if there is opening in the construction, it's great feature.
But often it is necessary to make a hole without cutting out the reinforcement (for example, at the phase of "reconstruction" - new holes are made in the overlap). Revit cuts a hole rebar anyway:
Perhaps you need to add the "Cut internal holes" parameter to the object properties:
We have to solve the problem by creating a "virtual" slab and installing the reinforcement in it. Fear and shame!
5 Comments
I really support this one! Not only holes, but all face based families (e.g. steel embeds) attached to the rebar hosts surface, will create a hole in the rebar mesh.
khudaev
Community Visitor
Очень нужна дырка без вырезания арматуры ))))
tureal
Observer
ryan.garza93ZE8
any update on this one? Trying to place a lift insert on a panel face however, a hole is cut in the rebar when it is placed.
If I model the rebar without using area reinforcement there is no hole but this dramatically slows down the work flow.
Autodesk Customer Advisory Groups
